USRP Software Radio
USRP configuration utility unusable
results are negativ. Even with quotes I receive the same error message "dict" object has no attribute "has_key"  (traceback line 522 in <module> )
HB-EUM
Message 21 of 33
(4,751 Views)
I need some rest: at work from 8:00 am. till now 00:45 am. almost 17 hours.
I'll get some hours of sleep.
Hopefully, Sarah, you have some good news for me when I'm back.
Best regards
HB-EUM
Message 22 of 33
(4,748 Views)
Accepted by topic author HB-EUM
Do you have any firewall or virus scan enabled? Is the USRP directly cabled? We have not seen this behavior before so something about the configuration appears to be unique.
Note that IP address can not be changed unless the USRP has the correct firmware version installed.
Message 23 of 33
(4,747 Views)
At last a good new, things are now working fine.
I see with the configuration tool my 2 USRP-2920 and I could update the image and firmware. Note that the corect ones were : ni292x_fw.bin and ni29x_fpga.bin
For that, I needed to remove the firewall !!!!  That is however not good!!!!
Thanks for the suggestion Erikl.
Well, now, I can program the USRPs.
thanks a lot to all for the support.
HB-EUM
Message 24 of 33
(4,734 Views)
Hi Sarah, Anthony and Erik,
I would like to thank you everyone for you help. I was in charge of the Service Request for HB-EUM.
Julien De Freitas
Applications Engineering Group Leader / Certified LabVIEW Developer (CLD)
National Instruments Switzerland
Message 25 of 33
(4,721 Views)
Hello -
It would be good to know what firewall software you were using and if you experiment further, which firewall settings seemed to work best.
Erik
Message 26 of 33
(4,713 Views)
I fully agree with.
This should be done in January. Stay tuned.
best regards
HB-EUM
Message 27 of 33
(4,706 Views)
Hello All
I need help in setting up NI USRP 2920 using GNU radio.
I installed the GNU radio and UHD and I am trying to connect to my USRP using the uhd_find_devices commmand but it sayd the no device is found? althought the device is directly connected to my host PC via an eathernet cable.
Message 28 of 33
(4,577 Views)
Please verify that the UHD diver is installed properly and that the IP address and Subnet mask for your PC are correct.  UHD is an open source driver and supported by the community.
Instructions are found here: http://www.ettus.com/kb/category/getting-started/getting-started
Erik
Message 29 of 33
(4,569 Views)
Hello Erik
I just need to change the hostPC Id to 192.168.10.1 and the subnet mask to 255.255.255.0 and the ping or use the uhd_find_devices command?? or do I need to set up an network??
thanks
Message 30 of 33
(4,556 Views)
