VXI and VME
VXI over GPIB on LV 2009 + Windows 7 Help
Hello.  I have no experience with VXI.
I have a client who hired me to code a VXI product that has been marketed as controlled by GPIB (The Chassis contains a GPIB interface).
I was informed late last night that I must use VXI PnP drivers to make this work.  (Long story, and I am not happy about it).
I am coding LV2009 SP1 on Windows 7.
I have installed NI-VISA and NI-VXI.  I can see the GPIB instrument in MAX.  I can even run the SCPI commands via Max and LabVIEW.  (The problem is that they apparently have not implemented the specific GPIB commands that they published).
They provided a VXI-PNP driver and very vague instructions.  I have installed that driver and I imported their .fp file into LabVIEW.  When I run their init code with the correct GPIB resource passed into the function, I get the same error as when I call a non-existent GPIB device- although it takes longer to return.
I looked for VXI tutorials on the NI site, and there is a LOT of stuff to wade through, and I am not even sure that I have all the necessary drivers.
Anyone know a good place to start reading up?
(And yes, I am dogging the instrument people to help me out too)
(8,552 Views)
Accepted by Jed_Davidow
Hi Jed,
From our conversation with your service request, I wanted to link the documents to this post for assistance with future issues.
Why Doesn't My GPIB-VXI System Show up Properly in MAX?
Getting Started with the GPIB-VXI/C
NI GPIB-VXI/C
Configuring T&M Explorer to Use the GPIB-VXI at a Different GPIB Address?
*NOTE: T&M Explorer is the predecessor to MAX
h_baker
Applications Engineer
(8,540 Views)
Thank you for the response.  The install info from the vendor was pretty poor.  I ended up getting them on the phone after three days and all I had to do was change the Resource string.  Their documentation had an incorrect example.
(8,537 Views)
