VeriStand
Calibration List in Workspace missing title
It looks like the Title of a Calibration object in the workspace (the one that is a List), can never be changed to anything but "calibration"... Is it a bug? See below.
Thx.
(6,015 Views)
As you can change the title of the Model Calibration Control Array and Medium I would guess it is a bug.
Note that the default name is "Calibration List" but it only reads "Calibration" from the start on.
I don't mind that you can't change the title, but I found something odd. If you have two models where the imported parameters have the same name, the names ony appear once in the "Available Calibrations" of the list. Can anyone confirm that?
Frank
(6,013 Views)
It's hard to say whether that's a bug or not, since this is still the calibration list regardless of what name you give the control.  This seems to be the expected behavior, where the title is for naming purposes only.  As far as the available calibrations, these calibrations are applied to the workspace based on the names of the channels their modifying.  Because of this, two channels with the same name will not be able to show up twice.  This is due to the separation between the workspace and the system definition file.  The workaround for this would be to name those two channels a different name.
(5,992 Views)
