VeriStand
Custom Device FIFO with multiple input/output
Suppose I have input 1 and input 2 initialized as two channels. How would I be able to distinguish between the two when reading from the RT FIFO (asynchronous device if that matters)? And like wise, what about for output?
(3,390 Views)
Accepted by topic author James9
You should be reading/writing an array of doubles from the RT FIFO, with the order of the doubles in the array matching the order in which they were created in your initialization VI.
Are you using the inline async custom device template?
(3,363 Views)
It didn't cross my mind that it took in arrays (I assumed it just took one value at a time). By order in initialization, you mean the device reference/subsection linking order, right?
 I'm using just the regular Custom Device Template Tool set to Asynchronous.
(3,357 Views)
You can retrieve those from RT FIFO array in RT driver. In this case,
index0 = 1st channel
index1 = 2nd channel
Certified LabVIEW Developer
GCentral
(3,342 Views)
Suppose I had a loop enclose around the input section to make input a & input b. Would the order, I presume, be 1st channel a, 2nd channel a, 1st channel b, and 2nd channel b?
(3,332 Views)
For loop would be executed two times.
1st is a, and 2nd is b.
GCentral
(3,311 Views)
