VeriStand
Error in adding signals for NI - CAN 8461 in Veristand 2010
I have modify the System Explorer.ini file to use the 8461 CAN card in veristand 2010 and the NI- CAN is appearing under "Hardware" in sys def. explorer in VS. But when I try to add signals under Incoming/Out going messages, error is appearing which is attached here. I have installed CAN driver 2.7.3 and Frame Channel conversion library in RT 8108. Please can any one tell me the solution for this error. And is there any alternate solution to use the NI-CAN 8461 in VS2010 since I don't have XNET card.
(5,441 Views)
Thanks you for your posting on National Instruments Forum.
If they want to add a database to the system definition, they can do the following:
To add a signal  is a little bit more involved:
I attached a documentation to help you.
Brice S.
National Instruments France
(5,391 Views)
