VeriStand
Error while deploying Simulink Model (.mdl file) on Target Controller in VeriStand 2012
I am getting the attached error whenever I am trying to run the VS project.
I have imported Simulink Model (.mdl) file in the System Def file.
(5,861 Views)
You cannot integrate mdl file in veristand.
You must compile mdl file in dll which is full compatible with veristand (a tuto exists on ni website).
Check also your controller configuration in the nivssdf to make sure ip destination of the deployment exists?
R.kaszubiak
(5,584 Views)
