VeriStand
How to pass data between different custom devices?
Well, i tried once per method. The second uses few functions. The context help of these functions tells about the possibility to use them only in inline cutom devices and mine are asynchronous. I can try once again: can i expect success? Other methods?
Message 11 of 13
(3,054 Views)
Finally i tried once again using the "Get data channel reference", passing the references of the channels and the one of the custom device containing them.
Unfortunately i get the error -307662 ("NI Veristand: node is not found in the system").
It seems like i need to use "external" structures like named queues... Doesn't it?
Message 12 of 13
(3,032 Views)
Please, see here!
Message 13 of 13
(3,015 Views)
