VeriStand
Peer-to-peer custom device only works on the PXIe-8821.
Peer-to-peer custom device only works on the PXIe-8821 CPU. We have a custom device for peer-to-peer communication between the FPGAs. This works with the PXIe-8821 CPU,
but if I install the PXIe-8862 or PXIe-8881 CPU with the same way as the 8821, no data is transferred peer-to-peer.
Do I have to consider the type of the custom device in the Custom Device project? I've only entered an RT PXI Linux X64 target without a specific type.
Does anyone have any ideas?
VeriStand 2020 R6
NI Linux Real-Time x64 6.1.38-rt12
(222 Views)
What version of driver are you using?
The only difference between these controllers I can think of is the minimum PXI Platform Service version.
Perhaps you can try if these hardware combination can work in pure LabVIEW ADE?
https://tmesystems.net/
(193 Views)
The latest PXI Platform Service driver, 23.8, is already installed. It's the same on both.
(178 Views)
Accepted by topic author Rokot
The issue is not with the PXIe-8862 controller itself, but with the Schroff PXIe-1082 chassis we use and the backplane topology. Unlike NI PXIe-1082, which has a non-blocking PCIe switch and allows Peer-to-Peer (P2P) streaming between all peripheral slots, the Schroff chassis only supports P2P between certain slots.
In the Schroff PXIe-1082:
  • Slots 5–8 are directly connected to the PCIe switch → P2P works reliably here.
  • Slots 2–4 are connected through bridges via Slot 1 (System Controller) → P2P is limited or fails.
  • Slot 1 is the controller slot and does not participate in P2P.
This explains why your custom device works when FPGA cards are in slots 5 and 6 (or 6 and 8), but not in slots 2 and 4.
On NI PXIe-1082, all slots connect directly to the switch, so P2P works in any slot combination.
Recommendation: For Schroff chassis, place P2P-enabled FPGA cards in slots 5–8. If full flexibility is required, use an NI chassis with a non-blocking backplane.
The PXIe-8821 is an older controller with PCIe Gen2 and less demanding backplane requirements. With Gen2, the bandwidth per lane is lower, and the P2P streams require less throughput → the bridge connections between slot 1 and slots 2–4 are sufficient. The PXIe-8881 and PXIe-8862 are modern controllers with PCIe Gen3/Gen4 and higher bandwidth.
(123 Views)
