VeriStand
Print NIVS Debug String.vi in a Model
Upon further investigation, the help files related to the RT VIs appear to be in Chinese.  I presume this may have something to do with why I can't read the titles of the sub VIs in the palette.
I tried uninstalling the RT Module, and reinstalling a version that I just downloaded today. (  LabVIEW Real-Time Module - English 2012  )
The newly downloaded version exhibits the same behavior.
Please advise.
GSinMN
Message 11 of 21
(4,163 Views)
Which version(s) of VeriStand do you have installed?
Jarrod S.
Message 12 of 21
(4,160 Views)
Currently working with Veristand 2012 Beta and Labview 2012
Tried all of this with the 2011 versions, and there were no problems (although there are not as many Real-Time related VIs in Labview 2011).
Message 13 of 21
(4,158 Views)
This is not related to NI VS, but corrupted LV Run-Time. Sometimes it happens when you didn't reboot when asked during installation. So try to repair LV Run-time.
Jiří from mobile device
CLA, CTA
Message 14 of 21
(4,149 Views)
This issue has been filed to engineering (CAR# 391066) for further investigation. At the time I do not know of a workaround.
Jarrod S.
Message 15 of 21
(4,141 Views)
Thanks Jarrod.  I'll keep trying to fix it on my end, and report back anything I find that might be useful.
GSinMN
Message 16 of 21
(4,131 Views)
Hello Jarrod,
  Checking back to confirm the bug fix.  I downloaded and installed the Veristand 2012 F1 Patch this morning.  From what I have seen with my testing, the problem has been corrected.  All palette titles now appear in English, as well as the associated help files.
Thanks to the NI team for correcting the issue.
GSinMN
Message 17 of 21
(4,097 Views)
That is great news. Thanks!
Jarrod S.
Message 18 of 21
(4,090 Views)
I can't find the RT Debug String.vi in either my Labview 2011 or Labview 2012 real-time packages.  Any body seen the same thing?
Message 19 of 21
(4,010 Views)
Hello Kathleen,
  You may want to check to make sure your license for the RT Module is still valid.  If the license is expired, some of the VIs may not be available.
GSinMN
Message 20 of 21
(3,999 Views)
