VeriStand
Scaling: Error -307888
Hi Forum,
I am using LabVIEW 2012 and NIVS 2012. Currently, i am designing my first system definition. I need to scale one of Analog Input from PXIe-6363 to some factor by using "Add Scale>>Polynomial Scale". I have always get error for any scale function i added.
It is an undefined error.
Someone has an idea?
Rajamodol
(5,901 Views)
Accepted by rajamodol
I'm not sure why you see no error explination. On my computer it says
Possible reason(s):
NI VeriStand:  A polynomial scale mapped to a channel(s) does not have reverse coefficients defined. Remove the mapping or update the scale to contain reverse coefficients, and then try to deploy the system definition again.
Stephen B
(5,891 Views)
Hi StephenB,
Yes, i only need to go to reverse coefficent and Generate it. Problem solved.
Rajamodol
(5,852 Views)
