03-20-2013 03:01 AM
Hi:D
I have problems with stimulus profile editor. When i press "+" to hide commands of for example if function, sometimes the commands aren't hidden and the function is copied. its little bit annoying.
can i do something with it? thank you for any help!
BR, Katerina
04-27-2013 02:51 AM
06-28-2013 03:58 PM - edited 06-28-2013 04:12 PM
It happens a bit randomely and screws things around. I have a bunch of nested IF Else statements and it is very tedious to figure out which one is the copied items that has been added by the bug.
hmmm... it looks more vicious actually. Some of the code lines duplicated by the bug, once deleted, seem to also delete the original code that was copied.
07-02-2013 06:59 AM
could you please post a screenshot?
07-03-2013 10:49 AM - edited 07-03-2013 10:53 AM
Here it is:
It seems to happen with IF Then cases, but also with Do While...Likely with others too. Below there should be only one "If MonitorDwel_ms" case. When I want to collapse the one that is highlighted the another one is added below. Then typically, before you realized what happened, you may want to collapse again, and a third one will be created.... If I delete the highlighted one or scroll to another IF Else with the keyboard they can be deleted...
Very quickly it becomes very confusing and not very usable.
Just to be clear: it happens when I click on the IF THEN ( or DO WHILE) icon/line to collapse its content.
L.
VS2011
07-03-2013 10:58 AM
07-03-2013 11:28 AM
Thx, yes I had seen this tip above.
I think NI should fix this, it is quite a nuisance when the scripts are growing larger. And that should not happen. It looks bad.
L.
07-04-2013 06:02 AM
It feels like a bug.
I couldn't reproduce the issue, I'm using Veristand 2011 SP1 on Win 7 32 bit
which OS are you using?
07-04-2013 09:29 AM
VS 2011
Windows 7 32 bit on one PC, 64 on the other , but using 32 bit version of software. It does it on both PCs
