VeriStand
veristand UDP buffer size?
what determines how much data Veristand is going to send when subscribing to Veristand channels using Veristand .net.
I would expect it to be a setting or a rule based on the project.  i am seeing new data every 66 ms.  would like that to be longer.
there is a max_packet_size property returned from IUDPChannelStreamSession.  should that value be routed to the UDP read?  or any higher number would be good too?
Thanks.
Stu
(669 Views)
Accepted by srm@viewpointusa.com
See Solved: Default Execution Rate 15Hz of Communication Send Loop
https://tmesystems.net/
(655 Views)
thank you.
it is frustrating that searching did not find this solution.
much appreciated.
Stu
(631 Views)
