VirtualBench
Can DC power supply channels be switched independently?
DC power supply voltage level and current limit can be set per channel but it seems that all channels can only be turned on and off together (either in the Virtual Bench application or driver VIs).
Is there any way of controlling the 'enable' of these channels separately?
Stuart
(5,834 Views)
Hi Stuart,
The 'enable' is for the whole power supply, as you noted. There is no per-channel enable.
You can set the limits of individual channels to 0 to effecitvely turn them off.
William Earle
Software Engineer
NI R&D
(5,832 Views)
