VirtualBench
Remove Multiple VirtualBench device name
Hi. We have an issue that need to seek advice.
The PC had been link with a few Virtuabench and it always remember it's device name although it had not been connetced. This cause the lab tech to be confuse and often select the wrong device. Somethimes, the Virtualbench had already been hook up with test circult. This will result of flipping the Virtualbench over to check it's device name not possible.
Is there a way to Remove unwanted VirtualBench Device from the list ?
Thanks and regards
(6,498 Views)
If the device is no longer connected, you can remove it by calling the "Remove Device" API (http://zone.ni.com/reference/en-XX/help/374540C-01/lciviref/remove_device/).  It should be on the VirtualBench palette under "Utilities".
Zach Hindes
NI R&D
(6,489 Views)
Accepted by ediva99
Ugh, I broke the link, and I can't fix it.  http://zone.ni.com/reference/en-XX/help/374540C-01/lciviref/remove_device/
Zach Hindes
NI R&D
(6,481 Views)
Hi, ZachHindes.
Thanks for the pointers. Could it fix.
cheers !
(6,438 Views)
