2 |
VBAI |
16 bit support for thresholds, detect objects, etc. |
Advanced edge tool will not work on low contrast 16 bit images unless the Straight Edge Settings; Minimum Score is set to 0 (make 0 default then?) Also the Advanced edge tool max score is 1024 so it cannot find edges with stronger transitions which often occur in high contrast 16 bit images. |
This is now available in Vision Builder AI2015. The Threshold, and Detect Object steps were updated in Vision Builder AI 2015. The Find Edge, Find Circular Edge, Advanced Straight Edge already supported 16-bit images in Vision Builder AI 2014. Thanks for the suggestion.
