Wireless Sensor Networks
How to make the connections on the outputs of the letter wsn 3202?
Goog  morning Engineers,
Hugo Santos
Student at ISEC - Master Mechanical Equipment and Systems
Message 1 of 12
(7,624 Views)
Connections to what?  What are you trying to control/measure?
Chris
Certified LabVIEW Architect
Certified TestStand Architect
Message 2 of 12
(7,618 Views)
The situation is as follows, I intend to obtain a value of output voltage of the deviceWSN 3202, through a condition imposed in labview (example attached), I intend tooperate a relay. But until now still can not get any kind of value.
Greetings.
Hugo Santos
Message 3 of 12
(7,612 Views)
Attached sending
Hugo Santos
Message 4 of 12
(7,611 Views)
Okay, that VI looks fine.
Are you not seeing the output values?
Do you read good input values?
Chris
Message 5 of 12
(7,608 Views)
Yes I see the input values​​.
But the doors do not get any output value.
(Attached will the calls made.)
Hugo Santos
Message 6 of 12
(7,605 Views)
You need to supply DIO Power (pin 17).
Chris
Message 7 of 12
(7,602 Views)
I've done that. I called the Power DIO - DIO 0 and not obtained anything. Will have to give the value in the program?
Hugo Santos
Message 8 of 12
(7,600 Views)
Accepted by hugosantos
Sorry, I'm very confused by your response.
You should not need to set anything about the power programmatically, just wire up a power supply to DIO Power and the DIO Ground.  Then your DIO lines should be able to output values.
Also, I do think you may need to setup the line as output.  This would be done from the project.  I don't remember which element it is, but it should be in some Properties menu (probably for the specific DIO line).
Chris
Message 9 of 12
(7,598 Views)
Thanks for your reply, helped a lot. I'll try again, and then say what was the result.
Regards.
Hugo Santos
Message 10 of 12
(7,594 Views)
