 jncuevas
			jncuevas
			05-05-2025 04:28 PM
Hello.  I am using a cDAQ-9185 and have installed a NI-9866 for LIN communication.  When I go to use the bus monitor or do other things in MAX it says Status Code -88705 "The specified device is not present in the system ...".  I get the same status with another 9866, but I do have other devices in the chassis that are working correctly.
Does anyone have advice on this?  It would be much appreciated.
Solved! Go to Solution.
 ZYOng
			ZYOng
			05-06-2025 07:07 AM
Try the steps in Error -88705 When DAQ Device Is Not Detected in MAX
When used in cDAQ, NI-XNET modules use the DMA FIFO of DAQmx hence try the steps related to NI-DAQmx driver as well.
05-06-2025 08:30 AM
Thank you I will try those.
05-14-2025 10:12 AM
Turned out to be the slot in the chassis. Moved the card to a different slot and it worked. I don't know if there's a problem or if slot 1 just supports less.
