Status Code -88705 With NI 9866 and cDAQ-9185
Hello.  I am using a cDAQ-9185 and have installed a NI-9866 for LIN communication.  When I go to use the bus monitor or do other things in MAX it says Status Code -88705 "The specified device is not present in the system ...".  I get the same status with another 9866, but I do have other devices in the chassis that are working correctly.
Does anyone have advice on this?  It would be much appreciated.
(1,030 Views)
Try the steps in Error -88705 When DAQ Device Is Not Detected in MAX
When used in cDAQ, NI-XNET modules use the DMA FIFO of DAQmx hence try the steps related to NI-DAQmx driver as well.
https://tmesystems.net/
(987 Views)
Thank you I will try those.
(976 Views)
Accepted by topic author jncuevas
Turned out to be the slot in the chassis.  Moved the card to a different slot and it worked.  I don't know if there's a problem or if slot 1 just supports less.
(875 Views)
