BreakPoint
Rube Goldberg Code
*duplicate post*
CLA
Message 1451 of 2,635
(11,828 Views)
@altenbach wrote:
I am always getting criticized for using complex numbers when dealing with simple 2D geometries. But look at the difference! (seen here)
(No FOR loop, no formula node, no squares, no square roots, no bundle, etc...) 😄
Smiley Surprised
Once again you've simplified the code by making it complex! I think this phenomena should be called "altenbach's paradox".
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 1452 of 2,635
(11,810 Views)
Is it really that more complex?  If you understand trig, it isn't really that more complex.  Though, that could be my Electrical Engineering coming into play where we use complex numbers all the time (for AC circuits).  However, if you ever do perform simplification using complex numbers, please use comments explaining it since it is obvious that a lot of people don't quite understand it.
Message 1453 of 2,635
(11,798 Views)
I guess my pun was a bit vague.
Simplified with complex numbers... get it?
Maybe it's just my nutty brain that found that amusing.Smiley Embarassed
Message 1454 of 2,635
(11,796 Views)
You garnered a titter from me at least!
CLA
Message 1455 of 2,635
(11,776 Views)
While we are on the topic of when to use CDB data type to simplify code (As opposed to missusing Dynamic Data Type  and "merge signals" no less!)
I had to follow Christian's exellent example here
Spoiler
Snippet's would be a wast of time with the missing typedefs and lack of means to simulate the actual signal so... if you're interested go look for yourself.  sorry
Message 1456 of 2,635
(11,692 Views)
Ok - I will admit that this is horrible.
This is my code and it makes me sick. I'm sure it's a Rube but I can't for the life of me work out how to un-Rube it.
10 functions all identical all doing COMs with 10 different Instruments of the same type. Need to run as fast as possible and probably have limited memory due to complex maths funtions taking place elsewhere on arrays.
(SubVI and all subfunctions are re-entrant to ensure parallelism)
Surely this is a rube - any ideas on how to fix it?
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 1457 of 2,635
(11,580 Views)
What if you would use an autoindexing parallel FOR loop and configure it for 10 parallel instances?
Do you have 10 different serial ports?
Message 1458 of 2,635
(11,577 Views)
I do have 10 different serial ports - what is this
" autoindexing parallelFOR loop "
I think I am missing something here
Message 1459 of 2,635
(11,574 Views)
Found it - thanks Genius!!
Message 1460 of 2,635
(11,569 Views)
