BreakPoint
Rube Goldberg Code
Nested For loops with N values of 24, 60, and 60 and 1000ms Wait.
Just a timer.
Cheers
Message 1671 of 2,635
(10,942 Views)
(seen here)
OK, I was told to use a FOR loop to process an array of images. I think an even better idea would be to put the code into a FOR loop with a 1 wired to N and duplicate that FOR loop as many times as I need. Unfortunately, I now get 3D arrays at the output tunnel.
(Look at the navigation window for the extent of the problem!)
Message 1672 of 2,635
(10,859 Views)
As if the multiple single run FOR loops wan't enough, it was the filepath constants inside them that really got me gobsmacked.
I sat there stunned until I read the filename you gave the image which finally snapped me out of it... looplooplooplooploop.png LOL! Smiley LOL
Troy - CLD "If a hammer is the only tool you have, everything starts to look like a nail." ~ Maslow/Kaplan - Law of the instrument
Message 1673 of 2,635
(10,855 Views)
Is there a better word than 'insane'?! Smiley Indifferent
- Partha ( CLD until Oct 2027 🙂 )
Message 1674 of 2,635
(10,854 Views)
Loopy.
PaulG.
Retired
Message 1675 of 2,635
(10,810 Views)
@altenbach wrote:
(seen here)
"Oh! you said "paralelized For Loop" not  "paralel For Loops"
Ben
Message 1676 of 2,635
(10,865 Views)
 Yes, maybe that guy is way ahead of us and is designing the code for the massively parallel quantum computer of the future. 😄
Message 1677 of 2,635
(10,846 Views)
Well to be fair if someone says to make parallel for loops, and you didn't know about that feature in LabVIEW, the literal translation seems appropriate.  Overly complicated, but appropriate.  So glad LabVIEW does this for us with a simple right click.
Message 1678 of 2,635
(10,784 Views)
Confesion time!
Once apon a time, in a program far far away...
I actually split up the array processing using parallel loops and it worked to improve the performance.
So who am I to judge?
Ben
Message 1679 of 2,635
(10,780 Views)
Of course nobody said anything like that in the quoted thread.
Message 1680 of 2,635
(10,766 Views)
