BreakPoint
fizbuzz - a simple coding challenge
Would it be cheating to just make an array constant of
1
2
fizz
4
buzz
and wire it to an indicator?
Message 21 of 41
(11,119 Views)
1
2
fizz
4
buzz
:rofl
I love it. Smiley LOL
Message 22 of 41
(11,109 Views)
This is my approach for this problem.
Message 23 of 41
(10,983 Views)
Except for the fact that your string won't show any numbers...
Message 24 of 41
(10,978 Views)
Numeric 2 shows the number and it is easy to add the number to the concatenated string.
Message 25 of 41
(10,960 Views)
Well, it is easy to write a program from scratch that fulfills all requirements of the challenge and yours does not even come close. 😄
  • You are slowly displaying a partial result, replacing the previous result. "Printing" implies that all results are visible once the program completes.
  • What is the point of the upper numeric indicator?
  • Your program takes 100 seconds to complete. That is longer than it should take to solve the challenge.
  • You have way too much duplicate code. Why do you need two copies of an empty string, for example?
  • Your code operates on numbers 0 ... 99 instead of 1 ... 100 as required.
  • Fail!
Message 26 of 41
(10,975 Views)
Hi altenbach,
Thanks for your detailed post. I am new and learning so it helps me a lot.
Message 27 of 41
(10,963 Views)
I tried to do it with no case structures and with the return being a single string indicator, not an array.  (Full disclosure: I totally stole the array input to Q&R from altenbach).
Seth B.
Principal Test Engineer | National Instruments
Certified LabVIEW Architect
Certified TestStand Architect
Message 28 of 41
(10,896 Views)
Not that I want to keep banging on about it, but if you can solve the fizz buzz challenge then you can solve the first problem at Project Euler. If you haven't come across it, take a look.
http://projecteuler.net/problem=1
CLA
Message 29 of 41
(10,860 Views)
No-one tried this?
PS: Don't mind the numeric conversions..
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 30 of 41
(10,831 Views)
