Certification
SubVI connector pane
for the enclosed text, the first line is load, 2nd line is config..
but how to edit the top "water"?
(4,329 Views)
Hard to say without the actual VI.  Most likely, it is coming from the owning library file.
GCentral
(4,306 Views)
Thanks.. but I did not get it..
"the owning library file", where is it?
I am wondering how to edit the text on the top..
(4,287 Views)
Then share your VI.  We can't diagnose a picture.
That depends on where you saved it.  It will have a lvlib extension.
GCentral
(4,284 Views)
it is from one of the subvi of the sample exam: sprinkler
THanks,
(4,281 Views)
Accepted by topic author idjuven1
That header is actually coming from an Icon Template that somebody made and applied to all of the VIs.  Since you do not have that template, it is kind of hard to edit it.  If you really want to get rid of it, apply a different template and use the Text Tool to apply whatever header you want.
GCentral
(4,277 Views)
