Counter/Timer
How to get counter values from pci 6221 card?
Hii
 I am using PCI 6221 card .. In that i am using the ctr o .. In my application i am using Linear encoder to measure the Lift movement.. so from software how to access the counter values i.e how much mm it moves...
(3,747 Views)
Measure Angular Position.vi in the LabVIEW examples will be a good starting point. Adapt it to Linear Encoder by clicking on the selector below DAQmx Create Channel.vi.
You can also create a corresponding DAQmx Global Channel (or task) in MAX and then use it in your code.
Feel free to post back if you need further help.
Message Edité par JB le 10-31-2008 02:15 PM
(3,744 Views)
