DASYLab
How to generate a square with a slope (talud-respons)
I want to generate a signal (square wiht a slope) you can see it in the picture what i mean.
With:
period is: 0,2 s
rising edge: 0,04 s
falling edge: 0,04 s
I can not find how i can make such a signal with the signal generator, how can i make such a signal with the available moduls in DASYLab?
I hope someone can answer question
Thankyou
(6,116 Views)
Which version of DASYLab do you have?
If you have the pro version, there is a module called Sequence generator that will allow you to generate that exact curve.
Tom Rizzo
InSyS Corp.
www.insyscorp.com
Your DASYLab integrator
(6,114 Views)
Accepted by Michelvl92
If you don't have Pro, you might be able to use the Generator module with a Triangle wave, and then use the scaling module to cut off the top, to make it more like a trapezoid.
A 5 Hz Triangle wave with an amplitude of 5, limited to +-2, will do it.
Measurement Computing (MCC) has free technical support. Visit www.mccdaq.com and click on the "Support" tab for all support options, including DASYLab.
(6,110 Views)
