DIAdem
Channel Events possibly
I am trying to calculate the time intervals between when a curve goes above and below a certain threshold value. That is to say, on an XY-plot with X representing time in milliseconds and Y the curve in question, I would like to calculate the time interval X1-X0 where X0 is the time when the Y curve goes above a certain value Yv (30 in my case)  and X1 is the time when it goes below it again. All calculated interval times then have to be stored in a channel called IntervalTimes.
I imagine it to be a ChnEvent problem but I am struggling since the update to Diadem 2017 as I still haven't gotten used to the news calculator, its functions and scripts.
Help would be most appreciated.
Tim
(3,402 Views)
Hi timpec,
Do you have access to the online courses ? If i remember well and if I understand what you want to do, that is the exact subject of an exercise in the DIAdem Basics course. They use the ChnFind function twice in a row to find both the events and then substract the times.
I don't have DIAdem at the moment but if you can't figure out how to do it, I'll try to send you an example by next week.
CLAMaxime -- Kudos are a great way to say thank you
(3,392 Views)
Accepted by timpec
Option Explicit  'Forces the explicit declaration of all the variables in a script.
DIM THRESHOLD: THRESHOLD = 0.01
Dim xChnl, yChnl, resChnl, resDescriptionChnl, i
Set xChnl = Data.Root.ChannelGroups(1).Channels("X")
Set yChnl = Data.Root.ChannelGroups(1).Channels("Y")
Set resChnl = Data.Root.ChannelGroups(1).Channels.Add("IntervalTimes", DataTypeChnFloat64)
Set resDescriptionChnl = Data.Root.ChannelGroups(1).Channels.Add("IntervalTimesType", DataTypeChnString)
For i = 2 To yChnl.Size Step 1
  If yChnl.Values(i) < THRESHOLD And yChnl.Values(i - 1) >= THRESHOLD Then ' If crossed DOWN
    resChnl.Values(resChnl.Size + 1) = xChnl.Values(i)
    resDescriptionChnl.Values(resDescriptionChnl.Size + 1) = "DOWN"
  ElseIf yChnl.Values(i) >= THRESHOLD And yChnl.Values(i - 1) < THRESHOLD Then ' If crossed UP
    resDescriptionChnl.Values(resDescriptionChnl.Size + 1) = "UP"
  End If
I added the description channel because you did not specify if you have to start with a down or an up crossing so if you are storing the crossing in pairs, you need a way to make sure you know if your initial crossing is above or below threshold.  No error checking here either
(3,391 Views)
Thank you. Appreciated.
(3,380 Views)
Just in case you are interested how to use the ChnEventFunctions
The following script loads the file, finds the events, calculates the time spent in each event and then calculates a channels which allows you to display where the events were found in the data
Call LogFileDel()
Call Example_EventDuration()
Function Example_EventDuration()
  Dim     LowerLimit,UpperLimit,oEvents,oChnEventDisplay,K
  LowerLimit = 30
  UpperLimit = NULL ' Setting it to NULL makes it an open intervall
  Call Data.Root.Clear()
  Call DataFileLoad(CurrentScriptPath & "timeintervals.tdm")
  oEvents = ChnEventDetectionWindow(Data.GetChannel("X"),Data.GetChannel("Y"),LowerLimit,UpperLimit,,,,,,,True)
  LogFileWrite("Number of events found: "&ChnEventCount(oEvents))
  LogFileWrite("Total time spent in events: "&str(ChnEventDuration(oEvents),"AutoAdj"))
  For K = 1 To ChnEventCount(oEvents)
    LogFileWrite(K&vbTab&str(ChnEventDuration(oEvents,K),"AutoAdj")&vbTab&oEvents(K-1,0)&vbTab&oEvents(K-1,1))
  ' Just in case you want to visualize the events found:
  Set oChnEventDisplay = Data.Root.ActiveChannelGroup.Channels.Add("EventsDisplay",DataTypeChnFloat64)
  Call ChnEventCreateStatusChn(oChnEventDisplay,oEvents,Data.GetChannel("X"))
  ' You can now use the "oChnEventDisplay" channel to display background segments in VIEW
End Function
(3,286 Views)
