DIAdem
Get value of a Channel by row number
I have recorded a script that calculates the N peak values of a channel and saves them into a new channel. Each channel contains the X value and the Y values of the selected peaks (PeakX and PeakY)
Now, I want to get the value of a channel on the PeakX values that I have saved from the Peaks calculation.
Groups = Data.Root.ChannelGroups.Count
Set oMyChannel = Data.Root.ChannelGroups(Groups).Channels("PeakX")
for i = 1 to Data.Root.ChannelGroups(Groups).Channels("PeakX").Properties("length").Value
' Find the row where the "[1]/Time" matches with PeakX calculated values rowToFind= pno("[1]/[1]",oMyChannel.Values(i))
'How to get the value of a 3rd channel on the rowToFind row next
 How can I get the values of a 3rd Channel on the rowToFind row?
Thanks in advance.
Martin
(4,722 Views)
There is a function in DIAdem - "ChnFind()".  Very handy.  Example:
Dim intMyResult
intMyResult = ChnFind("Ch(""Group1/Channel"")>10",250)
intMyResult will contain the first row above 10 and it will start searching from the 250th row in "Group1/Channel" (speeds up search in many cases). So in your case,
rowToFind = ChnFind("Ch(""[1]/[1]"")=" &oMyChannel.Values(i),1)
Dim ThirdChannelValue: ThirdChannelValue = oMyThirdChannel.Values(rowToFind)
Hope I understood you question.
P.S. there is a ChnFindReverse() function as well (starts the search from the end of the channel)
(4,712 Views)
Accepted by iparra
Hi iparra,
here is my interpretation of your request:
dim i, iRowToFind, iNewChnIndex, iLastGroupNo, oChnTime, oChnSource, oChnPeakX, oChnNew
iLastGroupNo = Data.Root.ChannelGroups.Count
set oChnTime   = Data.Root.ChannelGroups(1).Channels("Time")
set oChnSource = Data.Root.ChannelGroups(1).Channels("MySourceChn")
Set oChnPeakX  = Data.Root.ChannelGroups(iLastGroupNo).Channels("PeakX")
set oChnNew    = Data.Root.ChannelGroups(iLastGroupNo).Channels.Add("MyNewChannel", DataTypeChnFloat64)
iNewChnIndex = 0
for i = 1 to oChnPeakX.Size
  iRowToFind = pno(oChnTime, oChnPeakX(i))
  if iRowToFind > 0 then
    iNewChnIndex = iNewChnIndex + 1
    oChnNew(iNewChnIndex) = oChnSource(iRowToFind)
  else
    exit for
  end if
next
Greetings
Walter
(4,683 Views)
The link below shows how to use several DIAdem functions to get the row corresponding to a channel value.  PNo() is the easiest and fastest.
http://www.savvydiademsolutions.com/analysis.php?topic=search-channel-by-value-get-row
(4,135 Views)
