DIAdem
Hide x-tick labels (DIAdem script)
I am looking for a solution in order to hide the tick labels on an axis when creating a report with DIAdem script. Code snippet is:
Call GraphObjOpen(D2AxisXObj(1))
   ' Hide Ticks
   D2AxisXScaleType = "tick manual"   ' NO EFFECT IN REPORT
   D2AxisXTickType = "no Ticks"       ' NO EFFECT IN REPORT
   D2AxisXTxt = "Blaa"                ' WOULD PLOT "BLAA" in REPORT
   Call PicUpdate
CallGraphObjClose(D2AxisXObj(1))
Unfortunately this sample does not work, although I am pretty sure that I am modifying the correct grahics object, i.e. see the comment behind the variable assignments.
Can anybody help?
Daniel
(4,380 Views)
Hi MrDan,
You're really close.  Try putting the PicUpdate command below both the GraphObjClose commands in your script.  That is indeed the right property assignment to avoid tick displays:
Call GraphObjOpen("2DAxis1")
  Call GraphObjOpen("2DXAxis2_1")
  Call GraphObjClose("2DXAxis2_1")
Call PicUpdate
Brad Turpin
(4,374 Views)
Hi Brad,
thanks for the quick reply!
But the solution does not work.
Please see the attached sample plot: I'd like to have no text on the x-axis, except for the bottom plot.
Any idea?
Daniel
(4,372 Views)
Accepted by MrDan
Hello Daniel,
I think there is a misconception as to what the "ticks" parameter does.
"Ticks" are only the little lines on the X or Y-axis, they do not include the labels on the ticks, which you can influcence with these parameters (with the Object definition):
    D2AxisXSize      = 0
    D2AxisXColor     = ""
You can either set the color to "" (= no color) or the font size to 0, or both.
That should do the trick.
Let us know if you have additional questions,
     Otmar
Otmar D. Foehner
(4,368 Views)
