Hi, I would suggest adding a boolean called 'Include Dependencies' to the function on the scripting API to search for DQMH modules on the project, sometimes we have projects and we call DQMH Modules not listed on the project itself, but the developer should be aware we are calling those DQMH modules under dependencies, the Panther Dashboard for DQMH already is searching for DQMH modules under dependencies but it would be great if the native function does this functionality, also, I suggest adding a boolean array output to know if the resulting modules are located under dependencies or they are in the project.
This is how I visualize the connector pane of the 'Get DQMH Modules in Project.vi'
Thank you!.
