Would it be possible to include a boolean input to the Start Module VI called "Launch API Tester?". Set to False by default.
If TRUE, the Start Module would launch the API Tester upon being called. If RT target, then launch the RT API Tester VI.
Probably opens a big can of worms, but it would be pretty handy in some debugging cases!
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
NI Silver Partner and Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
DQMH Trusted Advisor
Hi @ChrisFarmerWIS,
Thanks for the idea.
We are declining the idea, but we will improve the CML example to show you how we encourage people to launch API testers for project debugging purposes.
Again, thank you for your input; it is most appreciated. Please keep those ideas coming!
