(DQMH) Documentation Generator
We just put Antidoc through a project with 22 DQMH modules, 40 libraries, and it generated successfully a 419 pages document.
The most important part is that the tables would be very useful during troubleshooting because I can see where all the requests are called and where the code registers for broadcasts.
Excellent work Olivier!
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
Message 31 of 40
(4,210 Views)
V1.0 has been released yesterday --> https://wovalab.gitlab.io/open-source/labview-doc-generator/posts/2020-07-15-v-1.0-release/
Enjoy!
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Message 32 of 40
(4,175 Views)
The architecture graphs are super useful, thanks for this great tool 😉.
Message 33 of 40
(4,171 Views)
Version 1.2.0 is available on vipm.io --> more info here https://www.linkedin.com/feed/update/urn:li:activity:6754688226461569024/
Olivier Jourdan
Message 34 of 40
(3,988 Views)
When I use the browser with the plugins enabled, I am able to see the UML diagrams.
but when I export to pdf, I just see the same text in the pdf as I do in the adoc format.
is there a trick  to getting the uml diagrams into the pdf?
EDIT:  If I use AsciiDoctor to create the PDf, I do not see the UML diagrams.   If I use Chrome to view the HTML page (with the extensions enabled), I can use the built in Microsoft Print to PDF to get the UML diagrams, but you lose the ability of clicking on the table of contents to jump to a section like you have in the HTML.
Kenny
Message 35 of 40
(3,958 Views)
Hi Kenny,
First of all, I would say that to obtain a full-featured PDF; the only way is to use the asciidocotor toolchain. So the right question is why you don't get the UML diagram when you use Asciidoctor.
Question: did use the following command to generate your pdf?
asciidoctor-pdf -r asciidoctor-diagram myfile.adoc
This should work.
Olivier Jourdan
Message 36 of 40
(3,945 Views)
For the record, version 1.2.1 is available on vipm.io. More information here --> https://wovalab.gitlab.io/open-source/labview-doc-generator/posts/2021-02-16-v-1.2.1-release/
Olivier Jourdan
Message 37 of 40
(3,936 Views)
Ah, ok, thanks for the help on the command.
I had tried running
asciidoctor-pdf basic-example.adoc
from the asciidoctor webpage.
Kenny
Message 38 of 40
(3,930 Views)
Accepted by topic author Olivier-JOURDAN
Some heads-up about Antidoc:
  1. New version 1.2.2 is available. As DQMH user you are more than encouraged to update because it fixes bugs related to DQMH modules parsing
  2. I created a LinkedIn page dedicated to Antidoc. I encourage you to follow this page to be aware of any news related to Antidoc --> https://www.linkedin.com/showcase/antidoc---the-cure-to-your-labview-project-documentation
  3. If you have any issue or feature request create an issue directly in the GitLab project --> https://gitlab.com/wovalab/open-source/labview-doc-generator
Olivier
Olivier Jourdan
Message 39 of 40
(3,619 Views)
I'm adding another channel for those who will be interested in discussing the Antidoc project in a more casual/direct way --> https://wovalab-open-source-projects.zulipchat.com/#
Olivier Jourdan
Message 40 of 40
(2,800 Views)
