Digital I/O
Generating a Digital Waveform Larger than Memory on PXI Cards
I'm looking for a means of sending large digital waveforms using a PXI Digital Waveform Generator. I looked at the HS DIO Cards, but their memory is smaller than the files that I want to transfer. My understanding is that the bandwidth of the PXI Backplane is 132 Mb/s. Therefore, shouldn't I be able to continuously stream out a digital signal from the processor memory to the card that is slower than that? For instance, 50 Mbits / second (equivalent to only 6.25 Mb/s)? However, my understanding after reading their manuals is that you cannot continuously stream a large waveform file from processer memory, you must transfer the file to the board memory first, and then transfer that out.
Does anyone know if there is a way to have a digital waveform generation card stream an arbitrarily large digital waveform straight from processor memory? Or, what is the fastest digital waveform generation pxi card that does not require the files to be put into board memory first?
Isaac
(3,794 Views)
Accepted by iBrow
Hello Isaac,
Take a look at the following developer zone.
NI-HSDIO Stream from Disk (Generation) Using Win32 File IO
Note that you will not be able to take full advantage of the maximum update rates of the HSDIO devices, because the data needs to be transferred across a bus.  Some other considerations are the data width as well as the HSDIO device you select, which may depend on other requirements not related to file or waveform size (for example the voltage standard or whether you need hardware compare).
Rod T.
(3,769 Views)
Thanks. That was exactly the information I needed.
(3,765 Views)
No problem at all!  I know that you mentioned you have existing files which exceed the onboard memory of our boards.
The ability to loop waveforms is a powerful feature of scripting which helps conserve memory. Creating scripts that loop waveforms may get you within the limits of the onboard memory of the device.  Generating from device memory will allow you to utilize the full updata rate of the HSDIO board as well as minimize the processor of the system controller.
Message Edited by RT4CY on 10-05-2009 01:00 PM
Rod T.
(3,760 Views)
