08-07-2009 02:22 AM
I use the example aiex1.cpp for a multichannel AI read with the mseries devices 6221 and 6229.
This example works for one channel, but the other channels have the same value (+- 0.001 Volt difference).
For example: I set 5Volt on the first channel and then the other channel have 5Volt too.
What should I consider in the configuration?
Solved! Go to Solution.
08-10-2009 08:54 AM
Hello Heiko!
your description sounds like that the effect you encounter is "Ghosting".
For further Informations on ghosting and on how to get rid of it, check these links:
http://digital.ni.com/public.nsf/allkb/73CB0FB296814E2286256FFD00028DDF?OpenDocument
and
http://digital.ni.com/public.nsf/allkb/C6C7DE575301A379862572DD00480A01?OpenDocument
Best Regards
Moritz M.
08-10-2009 04:50 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
08-11-2009 10:31 AM
thanks for all answers.
The cause of the same value on all AI-Channel have I found: I didn't connect all AI-Channels to a source. ![]()
@Joe F.: The aiex1.cpp didn't work with NI6221 and NI6229 without some changes.
The changes are:
in aiConfigureChannel(..), I use the constant tMSeries::tAI_Config_FIFO_Data::kAI_Config_PolarityUnipolar, instead kAI_Config_PolarityBipolar
and in aiPersonalize(...) I use tMSeries::tAI_Output_Control::kAI_CONVERT_Output_SelectActive_High, instead kAI_CONVERT_Output_SelectActive_Low.
I found this changes in some threads in this forum.
