08-07-2009 02:22 AM
I use the example aiex1.cpp for a multichannel AI read with the mseries devices 6221 and 6229.
This example works for one channel, but the other channels have the same value (+- 0.001 Volt difference).
For example: I set 5Volt on the first channel and then the other channel have 5Volt too.
What should I consider in the configuration?
Solved! Go to Solution.
08-10-2009
08:54 AM
- last edited on
11-10-2025
02:20 PM
by
Content Cleaner
Hello Heiko!
your description sounds like that the effect you encounter is "Ghosting".
For further Informations on ghosting and on how to get rid of it, check these links:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHy6CAG&l=en-US
and
http://digital.ni.com/public.nsf/allkb/C6C7DE575301A379862572DD00480A01?OpenDocument
Best Regards
Moritz M.
08-10-2009 04:50 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
08-11-2009 10:31 AM
thanks for all answers.
The cause of the same value on all AI-Channel have I found: I didn't connect all AI-Channels to a source. ![]()
@Joe F.: The aiex1.cpp didn't work with NI6221 and NI6229 without some changes.
The changes are:
in aiConfigureChannel(..), I use the constant tMSeries::tAI_Config_FIFO_Data::kAI_Config_PolarityUnipolar, instead kAI_Config_PolarityBipolar
and in aiPersonalize(...) I use tMSeries::tAI_Output_Control::kAI_CONVERT_Output_SelectActive_High, instead kAI_CONVERT_Output_SelectActive_Low.
I found this changes in some threads in this forum.
