FieldPoint Family
Generating Pulses with CTR-502
I want to generate 100 Pulses with a frequency of 0.27Hz. After having done no other pulses should be generate until told so.
How can I do that? I'm using an CTR-502 and LabView 7.1.
Any help would be great. I read most of the documentation but either my english is to bad or I couldn't find any solution.
Yves
(3,197 Views)
Hello Yves.
Sorry for me currently not having a CTR-502 at my hands.
Therefore I had to do some "copy and paste" from a project that I worked on in the late 2003.
I hope this VI is a helpful startup - although I could not test it before posting it to you (as already said: I don't have a CTR-502).
The VI is small, configurable and uses low CPU resources.
On a RT target like FieldPoint (FP) or compactFP this VI should typically run at least with "high priority".
I hope this will help in getting your job done.
BR, mgm
(3,180 Views)
