FieldPoint Family
LabVIEW reset of FP-QUAD-510
Hi all,
I've got a FP-QUAD-510 running through the FP-1000 RS-232 interface. I can read the counter but haven't as yet figured out how to reset the counter via LabVIEW.
Any hints.
Thanks in advance
(4,050 Views)
In FieldPoint Explorer, you should right click on the FP-QUAD-510 @x and choose Edit This Device, then click on Channel Configuration. In the lower right corner is a box titled Channel Commands, click on the Create Item button to create a channel named "Control @Ch0". If you press OK twice, you will now see a new item named "Control @Ch0". Anytime you write a "1" to the channel, it will reset Axis 0. Write a "0" for a no-operation.
If you are using the FieldPoint Optomux VI's instead of the regular FieldPoint VI's, use the !n, Execute Channel Command.
Aaron
LabVIEW Champion, CLA, CPI
(4,050 Views)
Thanks a lot.
(4,050 Views)
Excellent solution, now how about the same setup using MAX 3.0 and FP 4.0. I get a message...
'One or more attributes either do not exist or do not support the specified setting'
(4,050 Views)
Also in my configuration field point (I'm tryng with FP explorer 3 and 4 rev.)I have one of dual channel module which return the same message "this channel do not exist or do not support the specified setting".If i change the module the message remain the same at the specified channel....
Bytelabs.it
(4,050 Views)
