FieldPoint Family
using FP-CTR-502, LabView and OMEGA flow sensor (model: FTB602B) to measure flow rate
I was wondering how to configure the input channel for the OMEGA flow sensor so that I can output the flow rate of water (LPM) in LabView.  Any suggestions or examples are appreciated.
This link should take you to a site that displays the OMEGA flow sensor User's Guide:
If you are unable to view the link, here are the main specs:
  *Flow Range: 0.3-9 lpm (0.08-2.38 gpm)
  *Frequency Output- Square wave pulse, unscaled
     -Ouput impedance 75 ohms
     -Directly proportional to flow rate
     -Output- dc frequency
     -Offset 0.64 V
     -Peak voltage = supply voltage - 1.2V
     -Ouput signal cycle 66.7% (ie. at 100 Hz there is a 6ms "on" time and a 4ms "off" time)
  *Frequency Range: 40-1200 Hz (K-Factor = 8000)
Thanks in advance!
(6,938 Views)
LV ships with an example vi named Frequency Measurement.vi that is specifically aimed at FP counter modules.
(6,935 Views)
Ok, so I followed the directions for the Frequency Measurement.vi but I feel as though it's not working porperly (it's registering a new frequency reading NOT at the same time a the gating pulse freq.- takes a lot longer).
First I want to make sure my wiring is correct:
   *Pin 13 (Output 0) is wired to Pin 9 (Gate 0)
   *The OMEGA flow sensor signal wire is connected to Pin 2 (Count Input 1)
Should there be something wired to Count Input 0??  How does Count Input 0 generate a fixed-width positive gating pulse on Output 0 if those two Pins are not connected?
Also, does it matter what the values are for the Channel Attributes for Count Input 0 that are not listed in the directions (ie. Terminal Count)?
Thanks again!
(6,931 Views)
