I was wondering how to configure the input channel for the OMEGA flow sensor so that I can output the flow rate of water (LPM) in LabView. Any suggestions or examples are appreciated.
This link should take you to a site that displays the OMEGA flow sensor User's Guide:
If you are unable to view the link, here are the main specs:
*Flow Range: 0.3-9 lpm (0.08-2.38 gpm)
*Frequency Output- Square wave pulse, unscaled
-Ouput impedance 75 ohms
-Directly proportional to flow rate
-Output- dc frequency
-Offset 0.64 V
-Peak voltage = supply voltage - 1.2V
-Ouput signal cycle 66.7% (ie. at 100 Hz there is a 6ms "on" time and a 4ms "off" time)
*Frequency Range: 40-1200 Hz (K-Factor = 8000)
Thanks in advance!
