IF-RIO
getting started guide
hi ,
      As u said i went through the guide for 5640r but in the create fpga application section they are talking about a library file which is not found in the template folder..... i did follow all the steps that is given in the guide
what do i do next...... i am sorry i know i am asking too many questions but....... i have no one else to help me..... can u please help me out ??????
Message 1 of 22
(9,927 Views)
Hi Valli
I need you to tell me what page and what step you are hitting a roadblock with in the Getting Started Guide so I know specifically where you are.
Jerry
Message 2 of 22
(9,917 Views)
page 12 step 6 in gude for 5640r
Message 3 of 22
(9,911 Views)
Hi Valli
The step refers to the ni5640R Template.lvlib in the Project Explorer window.
This is what you should see:
This is what you want after finishing step 6.
Jerry
Message Edited by Jerry_L on 11-03-2006 05:25 PM
Message 4 of 22
(9,898 Views)
i dont see that.... the template folder that is in my system does not even show the host fpga and the lib file wen opened in the explorer window.....
i am seeing the example code in the labview-->fpga-->ni5640r-->example-->template.....
Message 5 of 22
(9,894 Views)
Can you attach and image of what you see?
Jerry
Message 6 of 22
(9,890 Views)
this is jus an example from another link but the same with jus the project name changed to template is wat i am able to see in the screen here
Message 7 of 22
(9,886 Views)
So, you copied the ni5640R Template folder to another location.  Renamed the folder. Then renamed the ni5640R Template.lvproj file.  And then opened the My Simple Spectrum Analyzer.lvproj?
Specifically the file with the .lvproj extention?
What version of LabVIEW are you using?
J
Message 8 of 22
(9,886 Views)
labview 8.0
Message 9 of 22
(9,878 Views)
yes i did all the steps that u have mentioned
Message 10 of 22
(9,878 Views)
