Home
Community
Discussion Forums
Most Active Hardware Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Can you pass pcm data using an enet/485 converter
NOAA
Member
10-27-2003
08:36 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am trying to pass Pusle code modulated(PCM)data across the ethernet, reconstruct it on the other end. Can this be done via an ethernet/485 convertor?
0
Kudos
Message
1
of 2
(3,178 Views)
Reply
Re: Can you pass pcm data using an enet/485 converter
Chris_Rake
NI Employee (retired)
10-27-2003
08:59 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Depends on how the PCM data is formatted. The Enet-485 outputs data in a UART frame (start, data, optional parity, stop) using RS-485 transceivers.
0
Kudos
Message
2
of 2
(3,178 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
