Cannot Communicate with NI-VISA and Tektronix Scopes
Using Ethernet connection to communicate using NI-VISA  to Tektronix TDS3014B and TDS3034B oscilloscopes. Cannot read data from scope.
See attached for configuration and Test panel dialogs. Was working previously.(Unsure which version was working).
Message 1 of 8
(6,514 Views)
Message 2 of 8
(6,490 Views)
Looked at the form, not relevent for me. Not using Labview. Using thrid party software(Fluke, MetCal) which is working OK.
Message 3 of 8
(6,486 Views)
So what NI products are you using? GPIB cable? Have you downloaded correct drivers for these equipments from our website? Available at the following links.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=164
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=168
Also make sure you go to start>> type "administrative tools" in search>>Services>>Make sure NI-Device Loader and NI-Configuration Manager are "Started" and "Automatic".
Message 4 of 8
(6,467 Views)
Use PXI GPIB Card PXI-6221.
Installed all drivers and software as advised. Checked NI-loader and Configuration Manager. All OK.
Had our IT guys take a look at my Windows settings. Can it be that an update from them could cause this problem. Two updates in question: winhttp.dll
and httpapi.dll. Not sure what they do.
Message 5 of 8
(6,420 Views)
You mentioned that this was working before in a previous version. Are you referring to a version of NI-VISA?
Humphrey H.
Message 6 of 8
(6,379 Views)
Yes it is NI-VISA. I did install the older version from 2012 and the error is still there.
Message 7 of 8
(6,325 Views)
Accepted by OLSTS
Ok can you try a different scope, computer, cables, and see if you still get the same erros?
Message 8 of 8
(6,306 Views)
