Date code of GPIB-USB-HS+
We have several GPIB-USB-HS+ devices in our factory, but we would like to know how to decode the serial number to determine the Date Code?
What is the date code of s/n: 2010AD0?
Please help.
thanks
-Cu Nguyen
(706 Views)
Please help.
thanks
-Cu Nguyen
How does it help? what do you intend to do?
Santhosh
Soliton Technologies
(699 Views)
We are going to send this device to our CM in Vietnam to test our products.  Vietnam customs requests the date code of each equipment.
(673 Views)
Entering your serial number at Instrument Certificate Generator - National Instruments yields the conformance certificate that lists the date of manufacture.
Here is the one obtained for the SN you shared,
Santhosh
(649 Views)
Thank you for your information.
(638 Views)
Accepted by redstar
Thanks.  The problem solved.
(552 Views)
Please make sure to mark the reply that answered your question.
"Thanks. The problem solved" is in no way an answer to your question.
Santhosh
(544 Views)
