08-26-2025 09:37 AM
We have several GPIB-USB-HS+ devices in our factory, but we would like to know how to decode the serial number to determine the Date Code?
What is the date code of s/n: 2010AD0?
Please help.
thanks
-Cu Nguyen
Solved! Go to Solution.
08-26-2025 09:56 AM
Please help.
thanks
-Cu Nguyen
How does it help? what do you intend to do?
08-26-2025 10:58 AM
We are going to send this device to our CM in Vietnam to test our products. Vietnam customs requests the date code of each equipment.
08-27-2025 01:00 AM
Entering your serial number at Instrument Certificate Generator - National Instruments yields the conformance certificate that lists the date of manufacture.
Here is the one obtained for the SN you shared,
08-27-2025 09:32 AM
Thank you for your information.
09-03-2025 09:21 AM
Thanks. The problem solved.
09-03-2025 11:09 AM
Please make sure to mark the reply that answered your question.
"Thanks. The problem solved" is in no way an answer to your question.
