Does anyone have a Hantek DSO-2090 working with labview
Hello, Do you think you could send me your Hantek VI as a LabVIEW 7 VI and the DLL as well?
Thank you!
Please email to goel(dot)tx(at)gmail(dot)com
Message 11 of 13
(2,765 Views)
HI Mattx055
I am having difficulty making the Hantek DS0 2090 to work with labview 2013 64bit. I have copied the dll and vi files to the my system32 folder. I opened the vi file in labview, but when I ran the program, it came up with 12 errors with the Call Library Function Node.
Please advise
Message 12 of 13
(2,535 Views)
Glad to see some responsiveness to LabVIEW drivers for this DSO.
However, I would urge great CAUTION when working with Hantek and clone products.
I have verified that the analog input bandwidth on these DSOs actually DEGRADES WITH THE NUMBER OF INPUT CHANNELS CONNECTED, not just the sampling rate getting divided.  In other words, you will see only full analog input bandwidth with 1 channel operation.  When you connect a second input channel, the analog input bandwidth degrades on all channels connected.  THIS IS NOT EVER SUPPOSED TO HAPPEN AND IS INDICATIVE OF VERY POOR QUALITY.
I shelved this scope and stopped using it after discovering the above behavior.
Message 13 of 13
(2,533 Views)
