11-14-2007 12:31 PM
11-15-2007
05:17 PM
- last edited on
05-23-2025
06:30 PM
by
Content Cleaner
Hi Mi,
Welcome to the NI Forums! MAX is an acronym for Measurement & Automation Explorer, which is not installed in Linux. Here is a KnowledgeBase about VISA Error -1073807202. I recommend reinstalling NI-VISA, and select LabVIEW support during the installation process. Also, there are other discussion forum posts related to this error that may help you.
Rima
11-15-2007 06:17 PM
11-16-2007
04:42 PM
- last edited on
05-23-2025
06:31 PM
by
Content Cleaner
Hi Mi,
Even if NI-VISA is installed, there may be a problem with the installation that is causing this error. There are a couple of tools in Linux you may use to check the communication. To access the Test Panel, go to a console and execute NIvisaic. To access the Configuration Utility, go to a console and execute visaconf. Also, which distribution of Linux are you using? NI-VISA only supports certain distributions of Linux. Also, which version of NI-KAL are you using? Also, here is another KnowledgeBase about Troubleshooting Serial Communication in Linux.
Rima
