 Spacecowboy
			Spacecowboy
			04-20-2007 08:00 AM
04-20-2007 02:11 PM
 J._Mondry
			J._Mondry
			10-09-2007 11:44 AM
We had the same problem and found the misunderstanding...
Prerequesits
We
use Labview 8.5, but it’s the same for 8.2 or below …
Installed
IVI 3.0 Compliance package
Installed
TQL Driver release 1.4 (from website) both CVI and Labview, even if only need
Labview
Attention:
there might be a bug in the installer. If you only install the Labview driver,
the TQL_32 DLL is not installed properly.
Checks
a)
Make sure TQL_32 DLL  is Version 1.4 (see img043)
b)
Check communication : in NI’s Max explorer use the VISA panel set the
appropriate COM (COM 3 in our example) to 19200 Baud and get nice communication through VISA (see
pictures 44-46)
LabView - the error
Open
Labview, open TQLP Initialize, set resource name to ASRL3::INSTR and start VI.
You will get the error as described by us and others on the web : timeout
expired. (see img042)
LabView - the solution
What
we are doing wrong here is not setting the channel to proper baud rate of
19200. We will have to mix VISA and IVI a bit here. But with a construction
like this (see img047) communication works fine …. (basically using the VISA property node to set the baudrate and then use the VISA Refnum as input for the IVI Refnum of the TQL Init function .
 Well, now one would like to put the images somewhere ... someone who is interested in this solution and has a server available for these may drop me an email at mondry@zeiss.de and I'll send him the screenshots ...
 K C
			K C
			10-09-2007 12:40 PM
Are you sure you posted this in the right thread ?
This one is about a TTi power supply
 J._Mondry
			J._Mondry
			10-09-2007 12:49 PM
 dimabro
			dimabro
			07-25-2013 02:40 AM
I had the same problem , but I'm trying to work with VBA , I can't read from the QL355TP , but succsefuly send commands, what can I do? please help
 Spacecowboy
			Spacecowboy
			07-25-2013 02:53 AM
Hi
If you have problems with these power supplies then buy a USB to RS232 converter, and then connect to the power supply using the RS232 connection on the back. That has worked for me in the past.
Hope this helps.
 dimabro
			dimabro
			07-25-2013 02:57 AM
thanks ,
does GPIB helps?
another thing, what files/drivers should I have? and where can I download them? - maybe I miis something.
 MathieuGuigue
			MathieuGuigue
			10-24-2014 07:57 AM
Hello Spacecowboy,
I'm using TTi powersupply via an USB connection and I have issues: I start my program and it works perfectly but from time to time, the communication to the powersupply seems to be lost and I have an "Timeout expired before operation completed" error.
I then have to restart Labview and the powersupply.
Everything (described upper) is up to date.
You told dimabro to work with RS232 via an USB/RS232 convertor and that it solved your poblem: may I ask why?
Is USB connection not stable for long time?
Thank you in advance for your reply,
Mathieu
 Spacecowboy
			Spacecowboy
			10-24-2014 08:14 AM
Hi Mathieu
The TTi power supply has its own USB to RS232 inside, but we had problems with using the USB connection. Buying a Star Tech USB converter and installing there drivers seems to make it alot more stable. Having said that if I am using several TTi power supplys together on the same system I buy a PCI to rs232 card these are much better for mutlple RS232 connections. You can then use the TTi driver without any issues.
Hope this helps.
Spacecowboy.
