N8754A- Power supply does not output the configured value at the first measurement
Hi There,
I am new dealing with instruments. I am using Power Supply N8754a. I downloaded the instrument driver from the below webpage.
It has two examples. I just modified both the examples by removing the while loop and making it to run once. (I made this change since I don't want any human intervention to stop the while loop.) They work fine when I set reset as false. But on reset (default in those examples), say, if I want to set to 5V, the power supply output is set as 0.01V (most of the times), or some value between 0 to 4 (sometimes), and rarely 5V. But when I read the power supply output for the second time, it is set as 5V. (By second time, i mean placing the measure API twice). I tried giving delay also. But it is not the case. It seems like the value is gradually increasing to reach 5V. But how much ever i increase the value, i am getting the required value at the second measurement. Not sure whether this is the default behaviour or I am missing out something.
1. Initialize>>Configure>> Enable Output>> Measure  ->Works
2. Initialize>>Reset>>Configure>> Enable Output>> Measure -> Doesnot work
3. Initialize>>Reset>>Configure>> Enable Output>> Measure>> Measure ->Works
Any help is appreciated!
Madhumithra
(5,928 Views)
How long are you waiting after resetting the instrument?
(5,917 Views)
I tried waiting for a maximum of 2 minutes after reset.
(5,912 Views)
@madhu27 wrote:
Hi There,
Madhumithra
What does the programmer's manual for the instrument say?
(5,903 Views)
I didnot find anything mentioned specifically related to this. Since the example program from NI had the while loop, i doubt whether this shall be the default behaviour.
(5,894 Views)
Accepted by topic author madhu27
Hi all,
Initially, I had tried giving the delay after reset, which didnot work. Now, i am able to get it work by giving the delay of 1.5s after enabling the output.
Thanks for all your reply!
Madhumithra
(5,885 Views)
@madhu27 wrote:
Hi all,
Madhumithra
That makes sense.  It takes time for power supplies (especially high current power supplies) to charge up their capacitor bank and get up to the set voltage.  I have seen some take as long as 3 seconds to settle.
(5,877 Views)
