Start NI Spy without asking for overwriting logfile
The GPIB interface card from NI is supplied with a software called "NI Spy" (version 1.4) which allows logging the communication on the bus to a file for troubleshooting. The software has an option "Start NI Spy with capture on". If the program is started with this usefull option it shows always a warning message:
NI Spy will log captures to the file "C:\capture23.spy"
If the file exists it will be overwritten.
Do you want to replace the file?
YES   NO   CANCEL
This message is shown in any case even if the file in question does not exist because e.g. it has been deleted before.
Is there any parameter, option or registry key that will allow a "silent" start of NI Spy with capture on but no need for user interaction?
(2,977 Views)
I tried to reproduce the bahaviour you described, but could not. I set the option you mentioned and activated the logging to a file, but I don´t get the dialog you explained at every start. I use Version 2.3 of NI-Spy, so you should upgrade your version, thren you shouldn´t get this dialog anymore. NI-Spy is installed with the GPIB, and VISA, so best would be to get the latest Version of these drivers:
(2,960 Views)
