anyone using an Agilent U3606A?
I will change this in the program. Thank you for the help
Message 11 of 21
(2,415 Views)
Change what? There is nothing wrong as far as I can tell. Actually put a probe on the VISA Write input first and report what is there.
Message 12 of 21
(2,411 Views)
I was trying to apply the changes that Jeff mentioned. However I couldn't get it to work. So I am still not able to turn off the auto range on my device. The auto range is causing delayed measurements in my VI.
Message 13 of 21
(2,386 Views)
Well, did you do what I asked? Did you actually probe what the VISA Write is sending? Did you turn on NI-Spy/NI-Trace to capture the write? Do one or the other and compare what the manual says to turn ofauto-ranging.
Message 14 of 21
(2,372 Views)
I just edited the read output vi and it took care of my problem. thanks for the help
Message 15 of 21
(2,359 Views)
Attach what you have done. I don't understand how a modification to a read can change what you said what a problem writing.
Message 16 of 21
(2,356 Views)
Message 17 of 21
(2,350 Views)
Can you post a screenshot of the pre-/after changes? I am using the supplied VI's as well and the configure measurement function just hangs on me. What i mean is that the Over Current flashes on the instrument, but it does not overcome this.
Thank You
Message 18 of 21
(2,266 Views)
Hi GHernandez,
It sounds like you're getting a different problem than what was previously posted. Are you using the drivers available on this page?
Cheers,
KyleP
Message 19 of 21
(2,231 Views)
Yes. I am using the VIs supplied by National Instruments. I've attached screenshots of the subVI calls and the Main Vi. I made a test vi that will call this function. It hangs at setting the current limit. It will flash on the front panel and not do anything else.
Message 20 of 21
(2,223 Views)
