could describe how a device hangs up the GPIB 488 bus
(3,301 Views)
Any damage on the GPIB transceiver of a device could potencially affect the operation of the whole bus.
DiegoF
(3,301 Views)
Technically, if the device asserts the NRFD or NDAC line when it is not actively participating in bus transmission, it could cause the bus to hang.
It could also be a bad cable that has accidently grounded one of the lines.
If you could provide more information on what behaviors you are seeing, that would be helpful. In addition, if you have a bus analzyer to see the hardware lines, that would also be helpful.
(3,301 Views)
