program for a RS232 instrument which connect to GPIB-232
Hi zqgan,
Page 3-4 of the manual has information about setting up the serial properties. Hope this helps. Thanks!
Ebele O.
Message 11 of 13
(1,692 Views)
I have a Minolta CA210 instrument, but i am not getting labview drivers for the same. anyone has is pls post.
Anybody has Programming Manual for the same Model???
Joe
Using Ver. 8.0
Message 12 of 13
(1,591 Views)
Hello Joly,
Here is the link that contains the information regarding color measurement for the CA-210.
There was another forum post which discussed this exact issue. The link to that post can be found here.
If you go through the post of deyyouung it should get you started on controlling and taking measurement with your CA-210.
Hopefully this helps.
Christian A
Message 13 of 13
(1,578 Views)
